Catalina 30mkIII Owner Modifications and Upgrades
Heater system for the cabin
posted 10-12-2011 by Paul Mirenda
I installed a HeaterCraft heating system for my cabin in my 2000 30 Ft Catalina MKIII. This uses engine heat while motoring to produce cabin heat, similar to a car heater.
This is an easy installation with clearly written instructions provided by the manufacturer.
Step One - Cut a hole for the heater vent. Be carefull to select the proper placement of the vent per the manufacturers instrutions.
Step Two - Mount the heater.
Step Three - Wire the heater to 12 volts.
Step Four - Plumb the heater hose inline into the path of the hot water heater.
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
CatalinaOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
