Catalina 30 Owner Modifications and Upgrades
Live aboard mods
posted 10-07-2008 by Susan Ray
As i liv aboard,I removed the original stove and replaced it with a convection oven and 2 burner, both 110v. The shelf above pulls out,has a teak handle in front and there is a cleat above to tie down all when sailing.
After removing gimbaled stove
To give allusion on more space, I added a plastic mirror to the back wall behind the frig.It reflects light and space.
Mirror over refrigerator
put shelves in locker and a 12x 12 louverd door that hold a 13 tv...next photo shows it closed.
TV and DVD in hanging locker
Tv locker closed. note: Re-inforced chain plates with teak plates when they were redone, being as I once lost a mast on another Cat 30 due to chain plate failure.
TV locker closed
Took the door off the head (use curtain for door)moved the frame forward to 2 from forward bulkhead and added large arched mirror to opposite bulkhead. It is attached with wood 1/2 blocks holding it out from wall and those really good Scotch pads.Ive sailed with it and its fine.
Head with mirror
Click image for largest view
Copyright 1997-2025 SB Owners, LLC
All rights reserved.
CatalinaOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
