Catalina 30 Owner Modifications and Upgrades
Cat 30 Mods
posted 10-07-2008 by Doug Arietta
Garhauer Upgrades,
www.Poliglowproducts.com on hull
Arietta At Doc
leaf table seats 4, mahogany
cockpit table
Note sprit from tech talks, moved cleat and added chocks.
Bow mods
What to do with a grill that is under the bimini
back Porch!
Paper template helps cutting rubber bottom carpet. V berth step in background
Carpet and step
Raised shelf and built in radios
Radio installed
Took me lots of time. Built as one piece to fit and then cut down center for 2 doors. Plexi comes out for screens
Screen doors.
A front and doors on the vberth shelf makes a neater storage spot.
More than a shelf!
Starboard shelf. Make cardboard template and draw square box in middle. Cut wood to be larger than template with appropriate size box hole in middle then trace cardboard outline on wood and cut and sand and cut and fit and cuss and fit and sand and screw and plug :-)
Close up those shelves
Plexi slides. Wife loves this addition.
Port cabinets
dumped alcohol fire starter and put in propane cook top. Stainless (RV cooktop)
Galley changed
Click image for largest view
Copyright 1997-2024 SB Owners, LLC
All rights reserved.
CatalinaOwners.com is not endorsed by or affiliated with any sailboat manufacturer.
